Newbie needs advice... Underclocking, CPU and GPU temps and testing
21 Feb 2019
Hi. Just finished to build this pc: Ryzen 2600X, Stock cooler, AsRock 470x Taichi, Corsair Vengeance LPX 3200, Sapphire Vega 64 Nitro+, Samsung 970 Evo 1TB, Thermaltake View 31 RGB w/ 3 140mm Fans and a Samsung 1080p monitor (is going to be upgraded soon).
Since I am new to the DIY business I have no clue how to qualitycheck the pc temperature- and otherwise, so i browsed the web and got me HWinfo64 and Unigine. I didn't alter the CPU settings in Bios, but tried to use the correct ram speed. Which by the way didn't work even when choosing the right Vengeance download in Bios. It still remained on 2133Mhz. Any tips here?
Before I did the test I used Wattman to customize the Vega according to this thread:
https://forums.overclockers.co.uk/t...king-undervolting-information-guide.18793012/
But when I checked back while testing the Wattman settings had gone back to balanced setting while still stating custom. Why?
Anyways I performed a Unigine test run for 10-15 min with HWinfo64 running and following settings, open case for later comparison with closed case:
Unigine settings:
API: DirectX11 - Quality : High - Tessallation: Normal - Ant.aliasing: x2 - windowed - resolution: System (1920x1080)
HWinfo64 Readings:
ASRock Taichi...: Current-Minimal-Maximum-Average (Temp in Celcius):
MOBO 44.0 - 38.0 - 44.0 - 41.3
CPU 59.0 - 42.9 - 68.8 - 56.8
VRM 46.0 - 36.0 - 46.0 - 42.3
GPU (#0): AMD Radeon...
GPU Thermal Diode 70 - 43 - 70 -49
GPU HBM Temper.. 75.0 - 46.0 - 75.0 - 63.5
GPU Hot Spot Temp.. 84.0 - 47.0 - 85.0 - 72.3
GPU CorVoltage 1.119V - 0.769V - 1.156V - 1.001V
Are these normal readings? Are the CPUand GPU temps to high? I have no clue what to make of all this. My only concern is not to burn out the components. Help appreciated. Thanks in advance.
Cheers.
