Newbie raid question
14 Nov 2006
Newcastle, England
I have a ssd 64gb with 550 read, and 120 write
If i wanted to do raid-0 i think thats what its called and have 1,100 read and 220 write
Do i need to buy another exact model? Or cud i buy a 60gb with 500 read and also 500 write?
RAID doesn't depend on models, it just works with everything connected what is able to work :)
If you plug second, but different SSD, RAID will synchronize to slower device speed. So it's why the best and recommended solution is to put two same models, exact = it gives you doubling speed, more or less.
BTW, you've got 550 read on your SATA-2 motherboard ? :) It's just numbers, and probably refer to compressed data.
Ah thanks for that :) i will do another crucial 64gb :D
And no sry thats a bit outdated , running a 4.4ghz i7 bundle from oc
Will have to update sig :)
Thanks again
