- 8 Jan 2012
Hi
I want to WC my CM HAF-X starting off with just the cpu but will hopefully do gpu's if I can find a block for them or change my gpu's, so want the loop to be easily change to handled this aswell.
System details
Asus P8z68-v pro
i5 2500k @ 4.5 (currently on zalman cnps 9900)
corsair vengance 4*4gig
Asus gtx 560ti top
Corsair HX 850
As stated a CM Haf-x
these are the parts I'm going for so far.
OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
(£70.82) £84.98
(£70.82)
EK Supreme HF CPU Waterblock - Nickel Plexi EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
(£47.49) £56.99
(£47.49)
Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
(£9.07) £10.88
(£9.07)
EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel [3831109845011] EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Nickel [3831109845011] £2.99
(£2.49) £17.94
(£14.94
I would really appreciate some help on choosing fans and rad.
been reading that most suggest Scythe gentle typhoon (not really keen on the looks so what makes them so great?)
Also what is the main diff in the xt 360 rad and the ex 360 or spending the additional £30 on the sr1?
Help choosing the right parts would be greatly appreciated
System details
Asus P8z68-v pro
Asus gtx 560ti top
Corsair HX 850
(£70.82) £84.98
(£70.82)
(£47.49) £56.99
(£47.49)
(£9.07) £10.88
(£9.07)
(£2.49) £17.94
(£14.94
