Sad to see the other thread gone
What thread? The "invite me to XYZ" one on Networks?
I can see why it was removed, but is was a great source of Usenet information.
Anyway back on topic. Sorry.
Starting release update process (2013-01-24 22:00:33)
using latest regex revision 1742
Applying regex 2 for group alt.binaries.*
Applying regex 1 for group alt.binaries.*
Stage 2
Stage 3
Found 0 nfos in 0 releases
0 nfo files processed
Site config (site.checkpasswordedrar) prevented checking releases are passworded
Processing tv for 0 releases
Lookup tv rage from the web - Yes
Tidying away binaries which cant be grouped after 2 days
Deleting parts which are older than 2 days
Deleting binaries which are older than 2 days
Processed 0 releases
Cool, out of curiosity, how much space did you allocate to your VM running newznab and how much retention on the indexing are you using?
Ah cool thats not too bad.
Can anyone help on my post above? seem to be stuck when I run the update_releases script, doesnt seem to be pulling anything down, and nothing is then showing under my groups/releases etc, not sure why.
I have tried a few groups now, it updates the binaries ok, but just not the releases.
Are you sure its pulling anything down during update_binaries.php?
The update_releases.php will do nothing if you have no binaries for it to run against.
I noticed much the same on the free version of newznab. Apparently (so a friend tells me) it's because all the regex is out of date. (You can apparently find some more up to date regex out there on t'internet with a search).
The plus version doesn't have that problem as the devs have kept it much more up to date.
Whether that's your problem or not is a different matter
Going to start fine tweaking this today, and possibly looking at tying things up, taking a few backups and writing some quicknotes just incase everything goes pearshaped from here on
Will try and extend the backfill days as I go, dont want to screw it all up at this point and have to start again.
