- 16 Jan 2003
- Nottingham
Yeah not using an ONT is stupid but it’s Virgin so no surprise.
I like it in that it's a bit unusual, cuts out another box that could go wrong. Appreciate it limits replacement options.Why? My understanding is that it means you're stuck with the ISP router, which is a big negative for thsoe of us who rely or want to use features that router will unlikely have. Unless I'm missing something? This is my main concern about the nexfibre/VMO2 rollout in my area, but it may be my only option to get beyond the rough 20 mbit/s I have now...
That and they put the outlet in the street nowhere near the ducting I laid under my driveway, meaning I also probably have to take the fibre on a run around the house somehow. I think they assume you want it run to the living room (like VM would have done before for TV services?) but actually the front door/hallway area is way better for me as that's where my current infrastructure is.
Nexfibre are like Openreach/Netnomia, so would be the ISP on top of that which is just Virgin Media at the moment.Does NexFibre have a network status webpage?
Or, would that information be handled by the ISP (e.g. Virgin)?
Thanks.Nexfibre are like Openreach/Netnomia, so would be the ISP on top of that which is just Virgin Media at the moment.
Depending on the garden they just cut a slit if its grass, they don't dig a big trench or anything. Harder if its paved or just driveway though.Thanks.
I'm not sure we'll be going ahead with getting Virgin FTTP installed now, because my dad keeps going on about damage to the garden or the house / risk of hitting cables etc.
Might have to stick with 48mbps FTTC, after waiting for years![]()
I drew a quick network diagram in MS Paint, I was just wondering if this network would work well:
I could upgrade the switch later, if speed becomes a bottleneck on the LAN network, but I think we will probably use a 1Gbps switch to start with (the ethernet cables themselves are Cat6A, so can handle upto 10gbps).
EDIT - I was thinking of buying a 2.5gbps 5 port switch, maybe a TP Link TL-SG105-M2 (5-ports), as these aren't that expensive. The Virgin router can handle upto 10gbps on a single port.
That's correct it's fairly simple, but the ethernet cable between socket A and socket B will be buried in the wall, and also need to go under floorboards partially.It's not really much of a "network" - you're essentially just plugging the switch into the back of the router, but rather than having a cable trailing indoors between the two, you're going outdoors instead.
OT but what is that connection called and can you get an adapter for an ethernet port to connect a different router?For OpenReach, City Fibre and probably any other FTTP provider you'd be correct, but Virgin like to be awkward.
This is what you get. Note the fibre link at the bottom instead of coax cable.
The contractor workers finished their work in my street on the 12th of August. On the same day, they installed a Toby box with a Virgin Logo on it in front of our garden.
Is it likely to be 3-6 months before we can actually make an order with Virgin?
I asked one of the guys in the street when he thought we might be able to order, he reckoned just a couple of weeks, because the fibre has not yet been blown through the ducts.
NexFibre have been rolling out fibre around here, and when VM started offering service I took a gamble and went for the M350 package.
It has been reliable so far (about a month). The Hub 5X seems ok but is restrictive if you want to do anything more than 'plug and play' - e.g. they have fixed it's IP address to 192.168.0.1 and you can't change DNS, so I had to change a load of static IPs back to DHCP before it was installed. I've got the WiFi disabled as I'm using my own APs so don't know how that performs. VM couldn't transfer our home phone line, so I've ported that to a VOIP provider.
Modem mode still isn't available - there are people who have managed to get it to work via a hidden web page on the hub but I haven't tried it yet.
