Next doors invasion of bindweed.
19 May 2019
Hi all,
Next door we have a lovely (elderly) lady who has a garden full of bindweed and it's doing its best to invade my garden too.
Some areas on our shared fence zone can be sprayed, in the main part of the garden, the bindweed is wrapping itself about a variety of potted plants.
Is there any kind of 'paint it on' weedkiller that anyone can recommend to kill the bindweed without killing my own plants.
I'm thinking of a paintbrush and strong chemicals to murder the bindweed down to the roots without harming my own collection of pot plants.
Should give me something to do while I wait for the next generation AMD processors.
Regards,
B.
Goto b&q and stand in front of the weedkiller section and buy something in a spray bottle.....
I’ve never found any chemical that would kill bindweed that didn’t kill everything else around it.
You could try one of those propane wands and burn back the bindweed in your garden hoping that the thermal shock will kill the roots.
Alas, there isn’t really any substitute for ripping the horrible stuff out by hand.
If its coming from the other garden why would you need to spray weedkiller on your plants, just pull out the bindweed and treat weed around the fence with a suitable product.
"Hi Neighbour, do you need a hand getting rid of that bindweed as I can see its taking over your garden and it must be hard work trying to keep on top of it?"
"You would? Great."
"How about saturday afternoon and I'll bring my gardening gloves."
There are two ways I've found to deal with bindweed.
1. SBK Brushwood Killer. Spray it on, and the bindweed should be dying within a week. It has the advantage that it doesn't kill grass or a load of other plants. It's very effective, relatively quickly. It looks expensive for a small bottle, but you dilute it 30 ml to 1.5 litres of water, so a little goes a long way.
2. Unwrap as much of the bindweed as you can (at least a foot). Put it into a ziplock bag. Spray any good weedkiller into the bag. Zip the bag as closed as you can, and just leave it. The bindweed will die, and you can chuck the bag. This is good if it's growing on a bush or something you can't spray directly.
Ideally you want to get into next door and spray all the bindweed. SBK will be fine on grass, but you need to check or test if it's all over other plants. Anything woody (like roses) will be killed, so you have to use the bag method instead.
There are gel stick weed killers like Roundup that should work. It's like a giant glue stick that you dab onto the leaves of the bindweed carefully, and you just get the weedkiller where you want it, but I don't know how well they work for something as tenacious as bindweed.
As with all these weeds, if the problem is in the next garden and your neighbour doesn't sort it, it will just keep coming back the next year, and you'll have to keep spraying. That's true of all weeding. Even if you go and sort out her garden, she could get it from her neighbours, or birds, or wind carrying seeds in, etc. Be prepared to expect it as ongoing maintenance.
"You would? Great."
Have you ever actually talked to your neighbours? more often than not they are less than cooperative in my experience. Though to be fair our previous ones were quite happy for me to use their drive to park vehicles on when moving out and our current ones seem pretty easy going but that is more of an exception than the rule :(
and it's an elderly lady - they can be cantankerous auld witches, especially if you dare insinuate they need help with something!
I believe those gels are just glycophosphate in a more usable form. They work in exactly the same way.
Bindweed is one of the hardest to kill off, dont try to dig it out unless you are really accurate, if you chop it up you end up with even more!
The best time for really killing it is autumn, it draws down the weed killer into the underground bit, you can probably kill it anytime with these level of weedkillers, but if its stuborn then do it in the early autumn
I used Glycophosphate to kill ground Elder which is even worse than bindweed, every tiny fragment of root will start a new colony, it took me three years to finally eradicate it (hopefully) It even killed a 15ft Ash sapling in under 2 months, one of the many that self seed in our rural garden
Yep anything that is basically a rhyzone (spelling) is exactly the same. japanese knot weed is another to add to the list.
