No get a 7950. Sonys GPU is worked out differently than a standard one. It will be CPU/gpu in one
The 8GB unified RAM should allow for way better textures. But the CPU might struggle to keep up with the GPU from what I've read. Remains to be seen if games will be 1080p with AA, AF etc. Probably not at first but the fact that both MS and Sony went with AMD's offering must mean something. Don't know why you would have 8GB GDDR5, surely at most the OS would need 4GB and that's if it's a full-blown Windows type thing - that leaves 4GB for framebuffer which is not fillable even with a Titan in most situations.
AFAIK devs don't "develop for Intel", Intel just has better IPC and a superior arch. I'm sure they send engineers for games with the "plays better on" logo but they still win in every other title.
What I mean by "struggles to keep up with the GPU" is that I read Jaguar is clocked at 2GHz, with lower IPC than Piledriver and the GPU is somewhere around the 7850 mark.
Well that's cheering, hopefully they won't need to drop below 1080p like the current gen dropped below 720p frequently (Halo 3 at 540p).![]()
what clock is new cpu running at?
isn't it something bad like 2ghz![]()
The next gen Xbox will be API compatible with Windows 8 from what I understand. This will mean that PC gaming and XBox gaming will sorta start to fuse. What that will do for PC Games, I am not sure.
