Having both fans (A12x25 and A14) and the U12A (D12) Cooler, I would agree that adding extra expense needed to grab a new set of fans isn't great. Great if it's free upgrade or free samples etc (dunno how you get those, would love to have a few more fans to play around with personally
), but not as an extra purchase expense.
From personal testing, I can tell you that the A14 at ~60% speeds is where the noise is imperceivably different from lower speeds. Once you hit anything above 60% or thereabouts, you'll notice the A14 cranking up. The A12x25 however, is only noticed once you reach at least 75-80% before you notice its cranked things up, or if the fan noise becomes annoying (not just air/wind rush noise). Used LNA in both fans. Whilst the numbers are not direct, but a rough percentage down would have both the A12x25 and the A14 giving roughly the same numbers for airflow and noise levels (but at different speeds); 76-81m2/h on A12x25 vs 84 on the A14/A15. The A12x25 at max speeds (with LNA) doesn't sound nearly as bad as the A14 at around 80% of its rated speed, so again, there's a certain amount of noise difference between the two, not a lot though, but it's there, favouring the A12x25 over the A14/A15.
So in short, the A12x25 is really comparable to the A14 or A15, but smaller and when running +20% more compared to the bigger A14/A15 speed (to retain same airflow and noise produced). The A12x25 only loses out entirely at the top end max airflow, but if you really are needing that type of airflow for cooling, you'd probably be after other stuff instead.
The A12x25 is better if your gear is 120mm based, like the U12A cooler. As fitting a larger fan won't really work as well. Hence why Noctua likely paired the A12x25 with the U12A. But for more larger devices, the A12x25 will work just as well as the default A14 or A15 that's supplied (as the D14 or D15) and can be moved to other devices as well as not be as hampered if airflow is heavily restricted. But when cost (or getting new A12x25's) is involved, it won't look so great. Again, nothing really new what doyll and I have already posted, just posting up however that the noise produced by the A12x25 is better (less noticable) compared to the A14, and that can be a major factor for some.
