Intel has moved away from that design strategy in favor of smaller pipelines that do more work per stage, and can therefore run at slower clock speeds.
The combination of all those architectural changes will allow Intel to outperform AMD's planned offerings for the second half of 2006 without having to resort to adopting AMD's integrated memory controller design, Eden said. "It will take at least a year and a half to two years to close such a gap."
LGA775 apparently, because if it wasn't for existing P4 motherboards having the wrong type of power supply on them they would have been compatible with existing motherboards. I'd guess manufacturers will have motherboards out very soon claiming to be both P4 and Conroe compatible.easyrider said:I dont care.
Intel aint getting my money!
What socket will these new conroe chips be on ?
Yup, dual core. Merom (the mobile variant) is also dual core.mmj_uk said:Is Conroe dual core?
NathanE said:You need a new motherboard for AM2 too. What is the problem?![]()
lowrider007 said:End of the day If your serious about owning a high end pc then I don't think a £100-150 m/b is going to stop you from having the best, especially when the arverage end user spends around 1k-2k on his/her system.
No they learnt that the NetBurst didn't scale as well as the marketing department had hoped and that their previous P6 design was betterElectronic Dave said:I guess they are learning a lot from AMD's excellent design
