Following on from my thread http://forums.overclockers.co.uk/showthread.php?t=18242584
I was wondering if anyone had any recommendations for an alternative air cooler that would essentially give me the same results.
The main difference I'm looking for is height, although I think this CPU cooler would look great in the case (NZXT Phantom), my current issue is with the side 200mm fan.
Ideally I would like to keep the fan, and the NH-D14, but if there's an alternative that's just as good then I'll opt for that.
So, the question I threw up on my thread about how the fan on the side would be mounted...
would it work or is there an alternative CPU cooler out there?
I do want to overclock the 2500K CPU as well.
Water cooling isn't an option and anything higher in price over the NH-D14 isn't either as I'm already over my budget slightly.
Thanks
Thanks
