- 27 Aug 2005
Don't think that Nilfisk sell one which is very strange.
Watching as I have the exact same issue with mine, also the C135i.
Thanks, let me know once you've tried it out, you can be my guinea pig.Hey Chris,
Think i have found the solution, you need to purchase the G5 lance to attach to the pressure washer gun and then your G3 lance attaches to the end of the G5 lance. I have ordered the new G5 lance so hopefully it all connects![]()
like rob said brushes on both nifisk&karcher patio cleaners are just curtain protection from thrown debris - and would wear out fast with any force.I did need to scrub, it made a much better job of cleaning compared to not scrubbing with it.
I'll try some of this in next amazon order, several forums suggest it.... so chemicals rather than lance enhancement is where I'd spend the money.
If you have a farmers market nearby, you can pickup a 20L container of hypochlorite ....
Happy to confirm it all fits and works. The only downside is that it doesn't feel as sturdy as if it was one piece.Thanks, let me know once you've tried it out, you can be my guinea pig.![]()
Thank you, where did you order it from?Happy to confirm it all fits and works. The only downside is that it doesn't feel as sturdy as if it was one piece.
Here:Thank you, where did you order it from?
Thanks, I've just ordered one.Here:
Nilfisk Replacement G5 Spray Lance | In Stock | CleanStore
CleanStore provides quality cleaning products for delivery across the UK.www.cleanstore.co.uk
well - having something with short stiff bristles - which isn't going to flick up bleach over me//clothing or onto adjacent grass sounded useful. - and I haven't seen brushes like it.
Brush With Short Stiff Bristles
For those who think it's easier to annoy you than to Google 'Brush with short stiff bristles' themselves.letmegooglethat.com
