The 110v won't work here unless you use a UK charger... which are relatively easy to pick up. We don't work on 110v. However, I'm not even sure that the Asia 220v would be the same as us - I bet the plug is still 2 pin.
I think if you bought either they'd work fine provided you got a UK charger for it.
