Nintendo switch advice? (spec me)
4 May 2012
Hi,
Looking for a switch for the kids snug, as i understand them they are a handheld and then play on the TV if you dock them.
i expect 90%+ to be docked play with two player mode, are there hardware benefits to the various models or is it just the screens?
more quality experience led than budget led but wouldnt prioritise features that are only present on the move.
Thank you wise ones
Between the switch and oled it’s only screen and battery. The switch lite does not dock, so wouldn’t be suitable.
Switch 2 announcement is in April with a release this year, so it might be worth either waiting or getting a second hand none oled to tie you over.
You sir are a star thank you
