no audio
Are you XP? If so go to control panel, sounds and audio devices, click on the audio tab, click the "volume" button and make sure WAVE is selected. Vista may be similar.
If you olnly have CD Input, Microphone etc in the box that comes up go to Options -> properties and tick it's box.
I'm on stupid vista, hopefully a new xp os will fix this.
Vista does not have the Wave option, just stumped a pc expert, why is it not there.
