OK so yesterday I disconnected all the cables from my pc and took the side panel off so I could measure my current AIO radiator and inside case as I have a new AIO coming which is bigger.
I put the panel back on and plugged everything in but the pc wouldn't boot. The gpu (1080ti) lights up and fan spins, low rpm. The AIO lights up and I can feel fluid circulating. I can feel my mechanical HDD spinning and the keyboard lights up. The bios led comes on to show bios1 (MSI X99a sli plus mobo). However the 2 case fans do not spin and there is no signal to the monitors.
I opened the pc back up and checked to make sure all connections were in properly. I swapped the power cable to the gpu as I had a spare. I tried the gpu in the 2nd pcie slot. Took the gpu out completely as well as the ram but everything remained the same. No boot and not even any sound from the pc, I'm not sure if this mobo does beep codes.
I got another gpu to try from a friend but exact same thing when I put that in so hopefully the 1080ti is fine as I don't have the budget at the moment to replace that.
So my thinking is somehow the motherboard has died? Could it be the psu? Unfortunately I don't have a spare to test with. Anyone recommend anything else I can try?
