I plunged and bought the following to start the workings of a gaming machine:
http://www.overclockers.co.uk/showproduct.php?prodid=BU-075-OK
I also got the Tuniq Tower 120 with it.
I tore (well carefully took out) my old kit from the case and spent a whole afternoon cutting my hands (i always nick myself while i'm in a case!) assembling the new gear.
Everything booted up great, installed Windows and whole pile of other stuff including most drivers. Everything was fine.
Bam, next morning i turn on, my computer makes a beep to say "i've posted ok", but no display. I strip the case and try to isolate the problem, switch graphics card, single memory, etc...nothing, nada.
by chance, i plugged in my old VGA cable (VGA - > DVI adapter included) to the card as the cable is still connected to the monitor. And "wayhay" we have display. So i'm thinking it's a PSU issue, there is not enough power to the system or something for the DVI. However, i have read that it's an issue with the DVI and there are workarounds. Something to do with drivers?
Not a huge deal as i have display, but kind of makes my great digital screen a little obsolete. Any ideas if it's the PSU? It only has the 4pin plug to go into the mobo, and in the instruction manual it does say it's best to use an 8 pin.
Here's my set-up:
- Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz (1066FSB) - Retail
- Abit IP35 Pro (Socket 775) PCI-Express DDR2 Motherboard
- Crucial Ballistix Tracer 2GB (2x1GB) DDR2 PC2-8500C5 1066MHz Dual Channel Kit (BL2KIT12864AL1065)
- SoundBlaster Audigy 4 PRO
- Alienware case
- Samsung SM226BW 22" Widescreen LCD Monitor
- XFX 6800 GT with Artic Cooler (i know!! I'm going to upgrade soon
- Tuniq Tower 120 heatsink
- DVD-RW 16x Pioneer
- 3.5 Floppy
- PC Power & Cooling TURBO-COOL - 510-ATX-PFC PSU
- WD 200GB SATA drive
Anyone any ideas if i should upgrade the PSU (especially since i'm thinking about a 8800 GTS 512MB upgrade)? Or should i leave the PSU and the "no display with DVI" issue is caused by something else?
Here's my set-up:
- Alienware case
)- Tuniq Tower 120 heatsink
- 3.5 Floppy
(Well, I have
