Hi all,
As some of you may have seen in the Samsung 226BW threads, I'm having abit of a problem with this monitor. Basically I can't get it to work using DVI. The Analogue works just fine at the correct res but with DVI I get a blank screen. I have tried two cables so I have elliminated that possibility. Also, both the DVI ports on the back of my 8800GTX do work when using a DVI > Analogue converter so it can't be anything to do with the ports on the card I dont think. The monitor does seem to be able to tell when a DVI cable is plugged in. If I set the monitor to digital, although I get a blank screen, If I pull the DVI cable out the back of the 8800GTX, the monitor comes up with a "check signal cable" message. I'm running the latest drivers for the 8800GTX and I have installed the drivers for the monitor. Anyone have any ideas what could be wrong? I have a feeling its either software/driver related or just a faulty monitor. I will try and see if I can test the monitor on another PC with a DVI port. Anyone have any ideas in the mean time?
