If I wanted to use my old Xbox 360 that had no HDMI output on my HD TV, would it be possible?
As far as I know you can't get HD via scart lead?
I will be playing it through my monitor at 1440X900 using a VGA cable so it wont matter much but I was just wondering.
Cheers
EDIT - I've just noticed that the orignal cable that came with it has a TV and HDTV switcher. If I switch it to HDTV it'll run in HD? I thought you needed an actual HDMI cable and output to get true HD.
Cheers
