1 Mar 2011 at 17:39 #1 giggity giggity Associate Joined 20 Nov 2009 Posts 23 Hi there, I bought the Goliath bundle a year and a bit ago. It used to run a 3.2 ghz but now it is just at 2.66ghz. I've used CPUID to check. It's a i7 920 CPU What's wrong with it?
1 Mar 2011 at 17:41 #2 welshdragon welshdragon Soldato Joined 28 Dec 2009 Posts 6,844 Location Wales doesn't cpuid only indicate what the current speed is ie when near idle it steps down thus showing a lower speed? Try running a couple of intensive things in the background with cpuid open so you can see if the speed goes up? For example mine shows as 800mhz in cupid when just browsing then bumps to 3.4 ghz for games etc Last edited: 1 Mar 2011
1 Mar 2011 at 17:42 #3 RJC RJC Don Joined 29 May 2005 Posts 29,049 Location Kent Pop into the BIOS and press F11 I think, this should give you a list of save profiles. If you look at the bottom of the screen before doing F11 it should read load CMOS from BIOS or something along those lines
1 Mar 2011 at 20:17 #4 welshdragon welshdragon Soldato Joined 28 Dec 2009 Posts 6,844 Location Wales Any news giggity? The suspense is killing me!
