No loop flow
Well theres water thats stuck up at the top left corner of the case around the gpu and cpu block area. Then the outlet of the pump which goes to the gpus has barely any liquid inside of it, and there is no movement in the reservoir.
my loop does this every this every time I drain and refill. I can hear the pump going but water in the res is not moving, found blowing though a pipe connected to the fill port on the res gets the fluid moving. might work for you?
Just had a thought, how am i able to run my pump at full as it its a pwm version without the motherboard. ALso i can't use it on my fan controller.
Well i did have the pwn cable running to another comp, but if theres an easier way then that would be better
Why won't your fan controller work?
Rigth, redone my loop again and whatever i do i cant seem to get any futher its driving me insane
just as i thought, well i cant help you other than suggest you see if you actually got the inlet and outlet right on the pump.
So much for more reliable :o
I know it may sound silly, but have you tried to empty out the water, and blew through a tube to make sure air can go through even?
To be honest, i'm stumped.
