No option for "keep aspect ratio" in Catalyst Control Center
Permabanned
4 Apr 2009
I'm using a Radeon HD4870 and it seems in the latest drivers there is no option to "keep aspect ratio" in the control center which means that non-widescreen games are stretched to fill the screen which looks stupid.
Any idea how I can fix this?
The option can be found in 'Desktops & Displays', click on the small monitor in the bottom left and select config, it's under 'attributes'. Stupidly you may need to lower the resolution a few notches for it to work, you can put the res back after.
Desktop and displays/Right click the monitor and select configure/In attributes enable GPU scaling and select maintain aspect ratio.
Beaten to it..
