Hi, I've just had a pc delivered from OverClockers. I removed the packaging from inside and plugged it into the monitor, but when I turn the pc on the monitor says No signal detected. The monitor works, and i hae tried with both a hdmi cable and a D Sub cable, both get the same message, which makes me think it's something wrong with the pc.
Bearing in mind this is brand new, is there something that needs plugging in inside the rig that I wont have done?
Thanks.
Incase it helps the pc is
Power Supply: OCZ ZS 750w PSU
- CPU: Intel Core i5 3570K 3.40GHz @ 4.30GHz Processor
- Motherboard: Gigabyte Z77X-UD3H Intel Z77 Chipset (Socket 1155) Motherboard
- RAM:Corsair Vengeance Low Profile 16GB DDR3 1600MHz Dual Channel Kit
- Hard Drives: OCZ Agility 3 240GB SSD & 1TB HDD
- Graphics Card: KFA2 GeForce GTX 680 LTD OC 2048MB GDDR5
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter (Black)
- Cooler: Prolimatech Genesis Black CPU Cooler
Thanks.
