No Signal through DVI connection to Monitor.
7 Jul 2006
When I turned my PC on yesterday my Monitor Neovo HW-22 showed no signal.
So I took the card out and reseated it, changed the power connections and still no signal.
It works fine when I use the DVI to VGA adapter on the card and use the VGA cable to the Monitor.
The Monitor is 3 years old and the GTX 560TI 1.5 years old and the DVI connection worked fine all the time. I already ordered anew DVI cable.
Any ideas what is most likely the cause of the fault ?
Thank you that put my mind at ease. I didn't think about trying to hook my ps3 up via DVI/HDMI, I'll have a look if i have an adapter somewhere.
Finally received my replacement DVI-D cable and still nothing...
So I now ordered a HDMI to DVI cable to thest the monitor with my playstation.
Finally got round trying the monitor with my PS3 and it works fine.
So I used a Mini HDMI to HDMI adapter that came with my GTX560TI and the new HDMI to DVI cable and it works!
Now I have no Idea why the DVI to DVI connection won't work anymore ?
