no sound from analog onboard audio after reinstall
8 Sep 2011
Northern Ireland
hey all need some ideas on how to fix this issue and what caused this problem. Im getting no sound from any 3.5mm jacks back or front after i did a clean re install. Optical audio works fine. Everything was working before I did format. Motherboard is ASUS P8Z68 V LX
So far I have done the following:
Using the default windows driver
driver from asus website
realtek HD audio r2.71 driver
rebuilt hardware and running bare minimum
enabled/disabled/enabled Realtek audio from bios
disabled audio enhancement from windows
used different speakers ( 2 different earphones and standard speaker all of them 100% working with other devices)
None of them worked for some reason. If I do a sound test or play a music file the green bars move up and down. Realtek HD audio manager detects the speaker (green circle is lit). Also i noticed that the pink circle icon in Realtek HD Manager is lit like a mic is connected even though there is none. Also tried disconnecting the front panel from the board and the pink circle is still lit:confused:
u mean this one ? I tried different options but nothing worked. I can only move the tick up/down and cannot do an 'untick'
unfortunately no :( . I couldnt get it to work. I gave up using the analog jacks and just use the optical
