you can turn wifi off on the virgin hub 3, i think you can on my asus router too
I just wondered if you could recommend an adsl or vdsl modem router were you can turn the wifi off. I don't if neighbours have wifi or not but in any case that's what she want's I couldn't find a modem router easily that has it.
I’m intrigued by this, in what way are they sensitive? What effects does it have on them?
There are a handful of Mikrotik routers that do not have wireless chips but none have ADSL modems built in. There are a few draytek models without WiFi but draytek you pay a lot for a mythical “enterprise reliability”.
What’s your budget?
She is electro hypersensitiveness, some people are sensitive to RF radiation in the same way others have allergies to certain other things.
Yet put them in a room with no visible RF sources and tell them it's RF shielded and they magically feel better, despite the multitude of high power RF sources on the other side of the otherwise ordinary wall.
The only thing real about RF sensitivity is the subject's anxiety about it
