I've decided to keep my system until it dies, and invest a bit into it now. I've got a Gigabyte GA-P35C-DS3R board with a Q6600, an XFX Geforce 8800GTX, and a Hiper 580w PSU. In an Antec Sonata II case.
Now it's quite noisy really, it's got the Hiper PSU fans, a 120mm Antec fan on the processor, on top of a Thermalright Ultra-120. And worst of all I think is the stock helicoptor on the 8800GTX.
I think the loudest of them is the GPU, now i've seen items like the Accelero Xtreme 8800 around. Is it going to be any quieter? And worth the cost? Though that cooler seems to be quite scarse these days, although i've seen the Accelero Twin Turbo about, if that's man enough.. Or maybe there's a newer cooler that works OK on the old cards, I was specifically searching for that card you see.
The fan on the CPU heatsink is easily changed, is there a huge variance in volume of 120mm fans?
Is it worth changing the fan(s) in the PSU if it's noisy compared to the others? if I can find a quieter one i'm sure it's just a case of popping the lid, and a spot of soldering providing they're the same voltage. (All components are well out of warranty so i'm not voiding any warranty.
Any advice would be great.
