The noise does not come from the capacitors. It never has, and it never will. The capacitors used on the card are solid state BTW. IE they are not film wrapped but set in aluminium.
Here is the 680 PCB (well, a googled pic)
Look at the components R30. They are inductors. Then go and read this.
http://electronics.howstuffworks.com/inductor.htm
As power enters them they buzz and vibrate. However, they should be set in epoxy and you should NOT be able to hear it. The fact that you are points to shoddy components.
Either that or the card is very over volted and overclocked, pretty much to the limit and it is pulling hard on the inductors.
Does any one know what the stock volts are? I know it's not possible to change them, but I would be interested to see how much voltage the card uses.
Once we know that we can compare it to the 7970 PCB and see how many components there are on both cards.
Edit. Bugger, that's a custom PCB Powercolor use.
Edit again. OK, this is the stock PCB. Note on this there are only four inductors.
So if the card is heavily over volted and or clocked out of the box that would explain why they squeal like piggies.
