** NOISEBLOCKER ELOOP FANS - FINALLY AVAILABLE IN 140MM **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Finaly they made it happen!
After 2 years developing a 140mm model from their existing 120mm model.
The 140MM eLoop fans will sell quick. Perfect for cases, CPU coolers and Radiators.
We will have stock in around 7 days.
Brilliant!
Noiseblocker NB-eLoop Fan B14-1 - 140mm @ £17.99 inc VAT
Hightech compact fans with bionic loop rotor (BionicLoopFan®). The special wing shape triggers turbulence in the air. This physical effect reduces the volume which is based on turbulances in the air flow and reduces energy consumption. With a straightened air flow and a higher Airflow these fans usually offers a higher overall cooling capacity over classical fans .
Features:
- 100% developed in Germany
- TÜV-certified sound level specifications = real data
- Extremely low-noise bionic loop rotor
- position-invariant magnetic bearing NB-NanoSLI® 2NEW!
- silent NB-EKA P2 Drive NEW!
- Bayer® Makrolon® rotor with anti-dust technology
- weighted reinforced fibreglass PBT frame
- NB cable management with two pluggable connection cables
- Perfect results for PC casing, CPU cooling systems and radiator( higher cooling power at same revolution ratel)
Includes:
- 4 fine thread screws and knurled nuts for tool free assembly
- 4 NB silicone slics for vibration-free assembly
- each 2x 20 and 50 cm connection cable with textile sheath
Dimensions: 140 x 140 x 29 mm
Volume: max. 5.71 dB (A)
Speed: max. 600 U / min
Airflow: max. 73,63 m³ / h
Starting voltage: 5V
Power consumption: 0.24 W
Connector: 3-Pin
Life expectancy: 160,000 hours
Warranty: 6 years
Only £17.99 inc VAT.
ORDER NOW
Noiseblocker NB-eLoop Fan B14-2 - 140mm @ £17.99 inc VAT
Features:
Includes:
Volume: max. 16.95 dB (A)
Speed: max. 900 U / min
Airflow: max. 109,22 m³ / h
Starting voltage: 4.5V
Power consumption: 0.66 W
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Noiseblocker NB-eLoop Fan B14-3 - 140mm @ £17.99 inc VAT
Features:
Includes:
Dimensions: 140 x 140 x 25 mm
Volume: max. 28.5 dB (A)
Speed: max. 1,400 U / min
Airflow: max. 178.29 m³ / h
Start voltage: 4 V
Power consumption: 1.92 W
Connector: 3-Pin
Warranty: 6 years
ORDER NOW
Noiseblocker NB-eLoop Fan B14-PS - 140mm PWM @ £17.99 inc VAT
Features:
Includes:
- Volume: max. 24.28 dB (A)
- Speed: max. 1,200 U / min
- Airflow: max. 142,59 m³ / h
- Starting voltage: 5V
- Power consumption: 1.44 W
- Connection: 4-pin PWM
- Life expectancy: 160,000 hours
- Warranty: 6 years
ORDER NOW
They're high end. They were never going to be mega cheap. Loads of research and science goes into these fans to make them good. They aren't just a cheapo OEM Chinese made fan done to hit a price point.
Of course not, personally I'll stick to slightly cheaper fans that work just as well and do the job :)
P.s you might want to edit the other thread too ;)
really pleased with the noiseblockers ive had before, if your really anal about a quiet PC (like me) they are worth it, only thing ive seen come close is some of the akasa fans, though the bright yellow tends to put me off those
Would getting 5 of the 600RPM models be sufficient cooling for a single GPU build in a 760t, or would I need to up it to the 900/1200 RPM models? Planning to get it as quiet as possible, whilst keeping the black and white look.
