Noisy Turbo!?
4 Jan 2004
¯\_(ツ)_/¯
Do turbo's get noisier before they bite the dust? I've got a Pug 205 TD, it's got 90K on the clock, and recently above 4000rpm it seems a lot more noisy. Now it's not exactly high tech engine like the one in a BMW 330D, but do most turbo's tend to last around 100k or does it depend more on how they are looked after and what sort of pressure and power it develops?
I do try and let it cool down and warm up, but I do like to put my foot down when I can. I have not done the infamous screw mod tho, it's pretty standard apart from a bit of air intake modification...
You used to be barely able to hear the turbo whistle even when it was revved to the guv'nor, but now it's much more noticable - it's like a really really loud whistley noise, similar to some of those Jap cars you see with silly huge turbos.
I may be able to get a sound recording tomorrow if that would help?
My turbo in my Mk5 golf died at 1yr, 10,000 miles. My turbo was/is still original at 140,000+ miles.
FWIW, it did start getting a bit noisier in my golf before it went, but the main indicator was that it started using a lot of oil about 500 miles prior to failure.
why are you taking a derv up to 4000rpm ?!
This - thats a bit like bouncing a petrol car off the rev limiter at every gear change - pointless
boost leak maybe? that will cause a noisy turbo, check your pipes arent getting loose
Also this, plus intake/exhaust mods can increase the turbo noise.
If you can, pull off the intake pipe and see if there's any play in the shaft
My one always used to give some turbo whistle and slight flutter :D
Sounds to me like you've got a boost leak or something dodgy going on with the exhaust though.
If a turbo goes, it goes... or if its on its way out the its likely to burn oil which you'll see ;)
Stick up the sound recording please, I sold my 205 2 years ago, and miss the sound!
Eh, no it's not. Even the lowliest of TDs will rev to 4,500. You rev high for the same reason you'd rev a petrol high - that's where you get the most power.
I rev'ed my 330d to the red line in the same way I would rev my M3 or 318 to the redline now.
if you take it above 4,000 on a regular basis, then i suspect the turbo probably is on its way out
My limiter's at 4600 and it's not exactly a lowly TD - its also a bit pointless revving it past 3500. You might feel like its faster because its noisier but it really isnt.
Why?
A turbo is a turbo.. just cause its on a diesel engine doesn't mean its going to break any easier :confused:
My 306 HDi.. makes peak Horse Power at 4145rpm I rarely take it there though ;)
Why?
It would be true for a petrol engine with a turbo - if you rag the nuts off it on a regular basis it's going to wear more quickly
That is why you use all the revs...
If you don't, you must be a hugely unenthusiastic driver.
It really doesn't. If you're sensible about it - I.e. let it warm up and cool down you shouldn't have any problems (I drive my N/A M3 the same way - take it easy until the oil is warm). As mentioned above, my 330d is on over 140,000 miles on the original turbo and I drove it properly.
My point was if you're not sensible about it ;) - I dont know how the OP drives...
No, 3995. :p
Because max power at the wheel's at 3400rpm?
That doesn't stop the car from accelerating though...:confused:
You still have a lot of power to play with up until the red line.
You've got every bit as much power lower down the rev range too, its practically flat after 2500rpm
Any diesel I've ever driven has felt pointless and noisy towards the red line, have always been able to make better progress changing up at about 75% up the range
i agree. i took it all the way to 5000 earlier this week for the first time in a year, and it really made no sense.
change up before 4000 rpm makes for quicker progress in my case.
twin turbo BMWs is a different story though
Try driving a proper one, I can assure you that you will make much better progress making full use of the revs - as you would in any car, petrol or diesel.
You're not going to be making good progress if you're constantly flapping about with the gears without taking advantage of the full rev range.
