- 3 Jun 2010
I have a budget of 400-700 and I need an updated pc to help with lots of graphics work, including animation of fractal content and 3d terrain, as well as PS Lightroom databases. I am mainly interested in the processing power and associated rendering speeds. Minimal gaming but something that can cope pretty well with modern games (e.g. fifa 2012) would be a bonus.
I already have a decent case, monitor and 6gb ram which I am hoping to use in the new build (will find out what spec it is). I may need to get a new psu (currently hiper 530w) and dvd rw if my current bits are not up to the new build (wattage and connectors etc).
I want...
W7 64b pro
i5 or i7
Asrock Extreme 4 3G or Asus z68
Minimum 1tb sata II (was looking at WD20EARS - 2tb)
I'm not sure about the gfx, psu or dvd drive.
Would I need a soundcard, or is that a tad old-fashioned?
Can you help with this? I would like some guidance on which bits go best with other bits.
My old bits will be passed down to my lad for a project of his, so not too worried about keeping too much of it.
Many thanks.
I want...
W7 64b pro
i5 or i7
Many thanks.
)is about cooling and does that change drastically if I do decide to OC the cpu?
