Dogbreath said:The 3SGTE is allegedly, but I know of 3SGE's that have had bent valves so I don't think they are. That would make sense as the 3SGTE has a lower compression.
It's not exactly simple to make a non-interference 16v engine with decent performance. The required combination of high valve lifts, longer duration and high compression are at odds with the requirement for plenty of valve clearance.
Both the 3S-GE and the 3S-GTE are "non-interference" but are both more commonly "semi-interference" due to the build up of carbon.
