noob build for diablo 3
some competitors may have some products lower or higher in price than OcUK. but never link or name them or the pricing...
don't want to see you get banned lol
anyways, welcome to the forums, if a bit abrupt!
maybe you can help again. (testing you now)
GA-Z77X-D3H has m-sata.
I was wondering if i can use my ssd listed above and purchase a micro sata, would they both work together?
"quote" specs
2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip:
2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
Support for RAID 0 and RAID 1
faster and cheaper then a normal hdrive ? and not as expensive as a 2.5" ssd
not really sure, just noticed the feature on the motherboard. so thought id ask.
is there a reason the 2550k is not as popular as the 2500k?
From what I have read the 2550k are just 2500s with faulty integrated graphics processors, so they disabled the IGP's on them and raised the clock by 100mhz.
If you plan to run the CPU stock you gain 100mhz, if you ever intend to overclock you gain nothing.
Btw in case your wondering DIII is a GPU limited game not CPU, an i7/i5/i3/etc won't make a noticeable difference (in tests anyway) over each other (in tests a 2Ghz Phenom II X4 gave 80% of the performance a 4Ghz i5 2500K did).
