noob ipod q
7 Mar 2005
Wolverhampton
How in the name of god do i delete an album off it lol
I dont use the sync thingy as i put music onto it from all my computers.
Cant even get ituned to display the current songs on my ipod?
ITunes never used to be this rubish
Been a while since I used mine but from memory .... you startup Itunes and delete it there then update the ipod through itunes ie. reload eveything again minus that album.... like I said been ages since Ive used mine.
I manually drag and drop music onto my ipod through itunes. I dont use the auto sync either. Just click on the ipod on the left hand side, then select what you want to delete in the main window. In the case of a full album, delete all the albums tracks. et Voila! gone.
The main window doesnt show you whats on your ipod anymore. It used to :confused:
So i cant see the tracks to delete.
Errm, can't you click on that little triangle thing to drop down the playlist/music library next to the iPod on the left bar? (or is that only in OS X?)
That worked for me, thanks.
I don't know why I didn't think of it before :confused:
It seems a cumbersome way of editing the iPod songlist though.
Isn't the easiest way to do it to select "manually manage music" then just select the tracks you want to delete? That's how I do it. Automatic updating is for suckers. :p
Thanks for the info ;)
Yeah I'm a sucker :o
