Ok cut a long story short i have wired all my rooms up in my house with Cat5e Cable no face plates yet just wires at the points i want them, I have connected 1 up with RJ45 Jacks using this wiring system:
1- White/orange
2- Orange/White
3-White/Green
4-Blue/White
5-White/blue
6-Green/white
7-White/Brown
8-Brown/White
This systems looks to be the same wiring as a shop bought ethernet cable. However when im using mine im only getting 100Mbps but as soon as i plug my pre bought 1 in i get gigabit!
The switch im drawing from is a Netgear Prosafe Gigabit switch GS108.
Can i only draw gigabit from this wire if its face plates at both ends? or should i be able to use it with Rj45's and get gigabit also?
Any help would be great.
Thanks Neil
			1- White/orange
2- Orange/White
3-White/Green
4-Blue/White
5-White/blue
6-Green/white
7-White/Brown
8-Brown/White
Thanks Neil
. But this is just a temp fix until i order face plates / jacks what ever they are wiring the same on those too ? Cant get that sort of stuff from overclockers can i?
