Hey guys,
Recently got one of those Belkin surge protection power strip thingies:
http://i.imgur.com/05yyu.jpg
And I wanted to mount it to a wall. Simple right? Just a simple screw in the wall job and hang the power strip off it right?
That's where the problem lies. This thing seems to have it's wall mount as an after thought, as the usual screw goes in then slides into a locking place doesn't apply to this. You have to somehow angle the screws in (which is impossible when the thing is up against the wall already) and even then you don't get a good fit. Pretty miffed as I don't want this thing on the floor. Searching the internet seems to yield no answers, so I'm gonna ask you guys if you have ever encountered anything like this, and if you have any solutions?
Otherwise I'll probably have to return it and get one of those standard long strips with the wall mounts that don't suck.
