Noob, want home cinema for TV
9 Nov 2015
So I want some better speakers for the TV essentially. It looks like I will be best suited to a home cinema system? I want to be able to hook up the tv and my xbox 360. I also want to be able to either play .mkv x264/x265 via usb or something through the unit, or just be able to plug a laptop or computer into the tv or unit and play them through the tv and the speakers, if that makes sense? I don't know the best way of doing this. I'd ideally like something sophisticated enough to configure placement of speakers so that it can adapt to the room it will be in? But I understand that is higher end stuff.
I think I am looking for a 5.1 system, with bookshelf front and centre speakers, and tall rear, but that is subject to change. The rears being wireless would be a big plus, but not essential.
Being able to just plug my phone into a 3.5mm jack would be awesome
I will use for watching tv, films, gaming and music.
A lot of bass is essential.
My budget is anything up £500, but if I can meet my needs with some of the £100 systems I am seeing that would be great too, not 100% sure how much of an investment I want to make, but I don't want to be disappointing with my purchase.
Thank you for any help! :D
You don't need to go "high end" to get features such as adapting the speakers to the room, but I'd definitely give both of those Sony systems and anything similar a very wide berth.
You can do much better for your money with a separates AV system consisting of an AV receiver and a 5.1 speaker package to which you add a media player for your .mkv and x264/265 playback and a cable to plug in your phone and HDMI cables for sources such as your console and an optical lead for the sound from your TV. In terms of connectivity both now and in the future this is a much much better option.
The sound will be better too. It's not about how many Watts. That's a smoke and mirrors trick used by the manufacturers. It's easy to tear down the claims of '1000W' and show you the truth of it that in reality the power claims are massively overstated. Go with the separates system and I guarantee you it will sound sweeter and have better bass and go louder for longer.
I'm glad you said that wireless rears aren't essential. The idea of 'wireless' is nice, but once you see the manufacturer's interpretation of it then you'll realise that you're just swapping one set of wires for a different set of wires and some extra boxes, and in the process the sound quality takes a hit too.
Google "SONY STRDH550 & Tannoy SFX5.1" which is an AV receiver and speaker package at under £300. You might also take a look at the "YAMAHA RXV379 & Wharfedale DX1" package at £479 which adds better quality speakers and a few more toys on the receiver. TBH though, either is going to murder those two Sony systems for quality and performance.
Thank you for your response, I was wondering if I'd end up going down the route of separate components. I can believe I will get a much better quality from the combos you are suggesting, I just need to justify to myself what the actual difference is i am paying for. I know sound is something you really have to hear, but is there any forms of numbers or materials etc. in a spec sheet I can see to compare what sets the different system apart? I don't understand exactly what i am looking for. I understand different frequency responses come into it? and the ohms of the speaker? But really unsure. I really want to invest in something good. But I don't want to spend a lot more than i need to as I will rarely be able to play it at anywhere close to max volume, though it is nice to have when I want to really immerse in a film or some music. are there any slightly cheaper separates systems you could recommend for comparison? between £150-£300 would be ideal, so the sony and tonnoy system is very much on the cards, i just want to understand what makes them so much better, not that I doubt they are. Thank you very much
If you want brand new Hi-Fi separates with 5.1 straight away then that Sony DH550 with those Tannoys is probably about as cheap as you'd want to go.
Now I'm not incredibly knowledgeable about all this at all, but it's occurred to me that buying 2nd hand and starting off with a 2.0 (just fronts) 2.1 (fronts with sub) or 3.0 (fronts with centre) setup means you can get higher quality kit at the same price. Then you can add further speakers later down the line as budget allows.
For instance I recently bought a Denon x2000w (rrp £500 a few years ago) for £95 (plus another 10% for 6 year complete cover), a pair of Q Acoustics 2010i's (rrp £99) for £60 and a Q Acoustics 2000Ci (rrp £110) for £85 all as clearance items from Richer Sounds. Sounds like a bit of a plug for RS (they aren't a competitor so no reason why not), and a massive brag, but they really do have some good deals in their clearance lines, so take a look.
Alternatively AVForums classifieds have some listings at very good prices from time to time if you happen to live locally enough to a seller.
The danger of buying second hand I think is mostly related to receivers (speakers tend to be fairly indestructible and last a long long time), so look out for transferrable warranty or anything like that. Or if you buy from RS you can get 6 year supercare for 10% of price - if you buy clearance and sign up for VIP membership (costs nothing, just give them your email address) you get 10% off all clearance anyway, so it's a wash.
Just something to think about
Those are all reasonable questions. The challenge you face is that not every justification comes down to numbers. If it did then it would be really simple to point to something better. So while your question is answerable, it does require quite a bit of background reading on your part to understand some of the physics involved behind those numbers. Then there's the physical things such as speaker cabinet construction (e.g. wood/MDF being better than brittle plastics at controlling resonance), and understanding why a satellite speaker with just one speaker driver trying to handle both treble and midrange (as in the Sonys) will struggle at both and how that manifests as a harsher sound that lacks definition.
Speaking of definition, you mentioned not needing to run the system at full volume; that comment suggests that you're thinking loudness is a good yard stick for quality. Again that's a reasonable assumption but it's generally one based on seeing big wattage numbers which is really just a smoke and mirrors trick. You see, it's not just about which set of numbers are better, but how those numbers are arrived at and also what information is missing from a spec sheet which helps give the whole picture. I'll give you an example, do you see a speaker efficiency figure on the Sony spec sheet? You're looking for a figure in dB or dB/W or dB/W/m. I'll bet you don't find one because Sony are aware that there speakers are pretty lousy in that respect and the efficiency figures aren't well understood by the general public anyway. Efficiency is really important though. It doesn't matter how many watts the amp claims to have, if the speakers are rubbish at turning that power in to sound then you'll still have a system that lacks dynamics and starts sounding harsh and compressed even at low volumes. The Tannoy speakers are 85dB/W/m. In a 20ft x 20ft room I'd need just 20 watts per channel to reach a sound pressure of 100dB. That's loud! You wouldn't play at that volume all the time. This is simply a yardstick to measure amp power converted to sound for this example. If I was being generous then let's say the Sony speakers are 80dB. The Sony amp would need to output 70W/ch just to match the sound pressure. That's 3.5 times the power requirement for each speaker. So what seems like a small difference in dB rating has big implications for system power. At this point you're probably saying that the two Sony all-in-ones have plenty of power. On paper they do, but in the real world they haven't. The way the numbers are measured means that you're lucky to get 1/10th of the quoted power in to a usable form at the speakers. That means 1000W is really more like 100W in total, and that 100W is spread across six speakers because they add up the total including the powered wireless sub which accounts for a much larger slice of the pie. The nett result is that the Sony all-in-ones end up running out of power even at modest volumes and that translates to sound that isn't that pleasant.
This brings me back to your point about volume. You shouldn't really be worrying about paying more because the system goes loud. What you're looking for is better clarity at low volumes. The better the system then the lower the volume can be and you can still hear good diction and proper timbre of instruments and good separation. The Sony/Tannoy system does it far better than the Sony all-in-ones, and the Yamaha/Tannoy system does it better again. There's no spec sheet number for this; it's something you have to hear.
Finally there's the practical things. This includes the simple stuff like there being more inputs on the AV receiver, but also stuff such as reliability. Again there's no set of figures to point to, but anecdotally most people here will tell you here that all-in-ones tend to fail much early than receivers, and the thing that goes is usually the optical drive. The cost of replacing that makes the set uneconomical to repair, so the head unit is toast. Since the speakers are matched to the head unit, and head units are impossible to buy individually, then the speakers are useless too so you end up binning your entire investment and starting again. Contrast that with a separates system. If the Blu-ray player dies then you replace just the BD player and not the receiver and speakers as well. Doesn't that seem like a more sensible plan???
If you want to do the research then go ahead. There's no doubt that it will stand you in good stead for the future. But if you're just interested primarily in keeping your money safe by buying the best you can for the budget then you might want to take a leaf out of the book from the people who live and breathe this stuff. Let us know if you want some pointers on further reading.
Thank you so much for your response, I will have a look at the clearance on richer sounds, and report back if anything seems appealing, however I think I am most likely likely to go with the sony and tannoy combo, I just don't know if I can justify the extra for the Yamaha without hearing it first. I would strongly consider second should it arise. I have also preferred a couple year old quality product over an inferior brand new product. I will likely report back with findings. Thank you again for such a detailed response.
I have just stumbled across these: https://www.gumtree.com/p/home-cine...samsung-av-r610-surround-receiver./1142497604 (which are only a 20 minute drive away), given there are only 5 5.1 speakers in a 20 mile radius period, and that these are the only ones that come with a receiver, I thought it was too much of a coincidence not to be fate. Just wondering if the receiver is any good? Or how it compares to the Sony unit? I have looked it up and found specs etc., but it doesn't mean a great deal to me. Cheers
EDIT: Research into receiver shows it is prone to having a noisy fan, and generally not a good buy perhaps? :( Shame as it would be a nice saving on the speakers. It also irks me slightly that looking at amazon's history for the tanoy and sony units they both dropped to £129.99 a piece at one point, combine that with flubbit for an extra 10-15% off and its a big saving again. As it stands that package from richer sounds still seems the best deal, unless the fx system below would be sufficient, at least for entry level, and perhaps invest in a more future proofed receiver with upgrades in mind once I have learned more?
Craig don't get any of the ones you've linked, they're all crap mate:D
The last one (Samsung AV-R610) is by far the worst, no HDMI and no HD decoding.
Do yourself a big favour and listen to lucid, you won't regret it:)
Those silver Tannoy FX satellites look surprisingly cheap. If you compare them to the other Tannoy SFX's, the silver ones look like they came out of a cheap Chinese copy factory; whereas the SFX sats look nicely made.
The SFX set would be a good buy, but the Samsung receiver looks poor. I'd get the speakers if they were available separately for a good price, then buy an AV receiver; whether it be new or second hand.
They're just the old version, 2004 here.
http://www.audioholics.com/soundbar-and-satellite-speaker-reviews/tannoy-5-1-fx
I have messaged the guy to see if he will sell the SFX 5.1 speakers separately, If not I think I shall bite the bullet and spring for the Tannoy and Sony system :D
though the fx are tempting, I mean even just the speaker stands (which I will probably have to buy if not to suit the room) are likely to set me back that? (£25)
That Samsung AV-R610 surround receiver is worth £20/30 tops!
So he's going to want top money for those speakers, don't forget they're only
£179.95 new.
http://www.richersounds.com/product/speaker-packages/tannoy/sfx5.1/tann-sfx5.1-blk
okay, dismissing the samsung av guy. but is the fx system worth it just for the stands? then maybe sell on the speakers? thought I may wall mount, was thinking stands as i am renting currently, but landlord doesn't mind as long as I make good, should only be two holes per speaker right? Only need to elevate the rears. Would the fx stands even fit?
I found this, but the reviews don't seem great and that is more than i'd like to pay, I'd sooner build a shelf myself
http://www.richersounds.com/product/speaker-stands/tannoy/sfx-stands/tann-stnd-kit-sfx-bk
I doubt those stands will fit the newer speakers, you'll have to get stands with the correct brackets for that exact model.
The SFX5.1 set does come with it's own wall brackets.
Got mine round the other way, fronts on stands and sides on the wall:)
https://www.gumtree.com/p/home-cinema/tannoy-surround-speakers-woofer-and-stands/1142737549 also if I am not mistaken is this not the same set, but in silver?!?! price seems too good to be true
I am pretty sure this is a tannoy fx 5.1, is that a lot worse? Or just the previous model?
Sound-wise there won't be a huge amout of difference from the front L,R and surrounds compared to the SFX speakers. The centre is much bigger on the newer kit though. That does account for a large proportion of what you hear during the course of a film.
The kit in your link is cheap. But it's cheap for a reason, and that reason is it looks very unloved. The satellites are quite dented and bashed. However, the stands and the fact that it's probably a genuine kit does make it pretty attractive to the right buyer. If it's still available and close by then I'd be tempted to go for a look just for interest's sake.
It's tempting to grab what looks like a bargain, but it's only a bargain if it is usable. Are you likely to want silver speakers? If so, then the stands alone would be a decent buy. But if black is your preference then sooner or later you're going to consider respraying the stands, and a couple of tins of satin black will cost £15-£20 plus the time and hassle. If you can sell off the other Tannoy bits to recoup some money then great, but do your homework first.
The fixing point on a lot of the FX/EFX/SFX/TFX range satellites is a screw thread on the underside of the speaker at the back edge. Make sure that whatever speakers stands you do buy should have a fixing to match.
Just bagged myself the sfx5.1 and sony STRDH550 bundle for £258.95 in the black friday deal today, could have gone into town to get them, but don't have a car at the moment, so opted for free delivery online, means an eager 5 day wait though. Am I going to need a cable to plug audio into tv or will it all be hdmi? Don't want to be without any cables I need to get going once it comes. Thanks for all your help guys
hdmi, does the sfx5.1 come with a sub cable?
EDIT : Included Cables Speaker/interconnect cables included with the package. Please note that in most cases, these are basic cables only and would often benefit by being upgraded.
