I've amplified this image in PS to show you what I've done tonight when trying to clean the sensor. I'm used to dabbing a couple of drops of eclipse fluid on a pecpad then use the swab to run the pac along the sensor as instructed. Done this for years and not had a problem.
Tonight is the first time I've cleaned the 5D3 sensor though and the fluid has left blobs running across that you can see and as such these show up in images faintly above f4.
Is sensor cleaning on full frame slightly different then or is the 5D3 sensor front layer protector of a different material or something?
I imagine I'll have to take it into LCE and get them to clean it properly now as the splatter pattern is dried fluid blobs.
