Norton Ghost + SSD
27 Oct 2009
West Sussex
Hi,
can anyone shed some light onto the backing up and restoring process of a system installed on a SSD using Norton Ghost?
Are there any cons of doing this?
Thanks
:D
how about the Acronis software then?
BTW. on my standard HDDs I never had a problem with Ghost... it actually helped me to find problems and bad sectors on one HDD before warranty expired :)
Norton Ghost the dos version is VERY old and doesnt support Win 7 officially. I would hate to trust it still.
I recommend Acronis for drive imaging. True Image 2011 can do a striaght clone and you get brilliant back up software.
Paragon Backup & Recovery 2011 (Advanced) Free ?
I recently gave my system a complete "refresh". I used Paragon to make a backup image of my SSD. I then restored that image onto an old HDD, so I had a backup of my system/files while I re-installed Win7 on my SSD.
Norton Ghost is one of the greatest programs ever made, I have many versions and if You know how to tweak it for odd raid controllers will work on virtually anything windows.....but I'm just referring to the Dos version, the only thing I have found is images made with newer versions obviously need the same or newer versions of ghost.
It's perfect for SSD's as it does not mess with the disk alignment (when restoring a partition image)
the Windows 7 built in image creation tool , works well, free and simple, if its just a system image you need
In the past when I've used that it makes a massive image, takes forever and I bet it will not install to a different drive without having to Jump through hoops etc. A simple recovery disk takes longer than the time Ghost could Image and restore !
