As has been said, Norton is pants. Even after you've removed it, it will leave a multiude of rubbish in your registry. I have not found a decent method yet of removing it other than manually.
I actually prefer an AV that lets you know that your AV Software has been updated, you know you are protected and the AV has started correctly.I Think AVG is excellent, update pop up is ok - only happens once when you boot. It definitely works hard though, and has always worked flawlessly, no viruses here in years! It automatically warns you about dodgy files before you open them!
Long time no see.norton just expired...is it worth renewing and if not how do i (fully) remove the software?
cheers![]()
And hi Gav!Long time no see.
I find AVG irritating when it pops a window up after an update.
Yeah it is.Probably because GPG is down atm.
You PM'd Glyn get about VT? You couldn't have a debut worse than Turkey_Machine![]()
Email me sometime or add me to MSN at marclister at gmail dot com.
