- 10 Jun 2010
- Scotland
Hi everyone,
I was looking at SSD's for a while and pondering over to get one or not, eventually I took the plunge and got myself two of the new Vertex 2e ssd's.
I set them up in a raid0 configuration using my onboard raid controller on the asus maximus formula.
The first thing I noticed was the installation of Windows 7 x64 wasn't at all quicker than installing to my old standard HDD, if anything was a little slower.
Program's also dont install lightning fast like I was hoping for, granted they were a little quicker at installing but definitely not £340 worth of a difference.
If I am opening multiple applications one after the other, then yes there is a difference but very rarely do i open photoshop, word, lightroom, e-mail and firefox one after the other rapidly.
One other thing that I found really strange was the benchmark results. The first day I was only getting results similar to the performance of one drive, they are definitely in raid0. Then all of a sudden the performance nearly doubles. I was installing all sorts and doing all the tricks suggested to improve performance, disable superfetch, disable indexing etc etc. So i'm not sure what caused the increase. I decided to reinstall Windows 7 again to make sure I never missed anything or it was a bad install. This time I used the "load driver" utility when installing and loaded the raid sata driver. I then got the higher set of results on first install so it must have been that.
So far the only thing I am enjoying about these drives is the noise, they are of course silent and it's bliss. My old 74GB raptor was terrible for noise.
Is there any tests I can do or can someone maybe try and reassure me I haven't wasted £340.
Any help would be amazing, and I am pretty new to forums so If I have made any fundemental mistakes, sorry in advance.
Cheers, Graeme
Cheers, Graeme
