Not getting any sound on a Asus 4CoreDual-VSTA
12 Feb 2004
Manchester
Not getting any sound on a Asrock 4CoreDual-VSTA
Hi guys
just set up a new build using the above mobo, using winxp with latest updates
have installed all drivers from Asus website including the sound drivers
but the sound device doesn't want to activate, i have the sound enabled in bios, but when i go to sound in control panel, it says "no audio device"
have read that there was an issue with a windows update that killed realtek sound and there was a patch fix out for it, i tried it but no luck
this is what it is: " 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec) - Realtek,
have also gone to realtek for the latest drivers and still no luck :(
don't know what else to try really, has anyone had the same problem?
bought this mobo while back from MM, not used it until today
speakers work fine and also using the Green port at the back of the mobo like usual.
any advice?
What does Device Manager say?
this is also a weird one
not sure what the pci device is, as i dont have any pci installed apart from a x700 pci-express gfx card which i have installed cat 8.1 drivers for.
i have however 2 sata hard drives and 3 ide hard drives installed.
XP is running off a sata hard drive fine
any ideas?
Realtek just release new drivers for their HD audio - have you tried that? I have the same board, although I call it an Asrock (aren't they made by asus anyways?) and sound have never been a problem for me....do you get the little realtek icon in the system tray?
when i install the drivers, (i know from past mobos), i should get the icon in the system tray
with this one, i get nothing, installs like usual, then says must restart
so i restart and nothing!
i think my only option at the moment is to use a pci soundcard, no biggy mind.
using XP Pro as my OS
one thing i did install which was out of the ordinary was when i did windows update, there was an update for my saitek eclipse keyboard, it was optional so i chose that, it was called "HID drivers" or something.
i think i did this before installing the sound drivers.
i may try uninstall this tonight and see if that cures the problem.
Shouldn't be affecting anything.
Also, asrock and asus and completely seperate entities, although I believe they have the same mother company. If your downloading Asus drivers, I wouldn't be surprised if that's why it isn't working.
Have you installed everything from the driver CD, and most importantly the motherboard drivers? (prob via 4 in 1 or something like that).
First check in the bios that on board sound is enabled, secondly remove the pci device (with question mark) from the device manager and redect, or reboot. Hopefully it should then install.
There is no reason why it wouldn't be working.
Matthew
Matthew
yeh my bad, that was a typo, i am using the asrock drivers
the mobo didn't come with a cd, but used the site to get all the latest drivers, am using bios 2.2 which i believe is the latest bios
have installed the Hyperion 4in1 drivers which installed fine
il delete the pci device and reboot tonight and will update on what happened
thanks!
thanks!
If you get issues, I can try and copy the original CD for you or send original files etc :) (free I mean).
I would be tempted to remove the drivers first, then delete the pci device. (or try reinstalling the pci device drivers (right click on the icon and reinstall drivers of your choosing).
BTW, I'm using the original bios with absolutely no issues. Not sure why anyone would change?
Matthew
hi guys
right, got to the bottom of this
turns out i was using a build of xp with sp3 integrated, this is beta and there a load of people having the same problem as me
i found on a forum, someone had made an addon patch (like an update), this fixed the problem and now i have sound!
thanks for everyone's help
much appreciated
lol, nice one :D When you said 'all the latest update' hadn't taken into account you'd gone a little further than most! ;)
Glad you sorted it.
Matthew
