not much TIM
3 Aug 2010
hi i went to put some TIM in when i realized i didn't have much left.
do you think this will do?
if not, will it be enough to boot and check my temps?:(:(
mate if you cant see what it says on the chips thats enough.... a pound says when you put the cooler on and test your temps your have lower than you use to! people forget its ment to be a super thin layer to replace the air gap between the two peices of metal
cpu to hsf should be metal on metal, paste is just there for the microscopic divots in the metal.
Actually creating a whole sandwiched layer of paste would be real bad, usually it would come out the sides anyway
It's better to put a blob in the middle and then press and wiggle the heatsink a bit, if you spread it first then you get trapped air bubbles.
