Not sure what GPU to upgrade to?!? Someone help!
12 Dec 2024
United kingdom
I've decided that I'm going to upgrade my pc as I've had it for about 5 months and built a budget build to start. Now I would like a better more powerful pc. However I'm stuck on what GPU to get, I'm going to get a Ryzen 5 5600x but I am stuck on whether to get a 6650xt or a rtx 3060. What would people recommend (I mostly play Fortnite)
If you can, wait. New nvidia 5000 series is due for release early next year, perhaps even January. Even if the cards are outside of your budget it should lead to prices for older cards softening as people replace their cards.
What is the current pc specs and your budget?
If solely for Fortnite and if you're not one to tinker, then I would advise to stick to an Nvidia graphics card because radeons have issues with running dx11 performance mode
(The workaround is to use dx12 so no biggies)
