Not sure what the problem is?
23 Dec 2010
Newcastle, Staffordshire
Yesterday whilst playing Minecraft the game suddenly locked up. I then got a message saying "graphics driver had stopped responding but has recovered successfully"
I restarted the machine but as soon as I loaded up Minecraft the system locked up, the screen then flickered black then came back on, each time the display had refreshed to the next, frame if you will.
At this point artifacts appeared on the screen. I assumed it was due to my graphics card so took it out and cleaned it, tried it in the other PCI-E slot, changed DVI port. But the problem persits. Sometimes the issue happens just on the Windows desktop and always when opening CCC or a game.
I've put in a ticket with XFX to see if i can get it replaced as i've only had the card for 1 year and 2 months(i've heard XFX have a 2 year warrenty)
Whilst that is on-going with a technician online i'm running off the onboard Intel HD graphics chipset. Now the above problem hasn't occoured. However after playing Minecraft for about 20 minutes, the computer just randomly switched off. I've never known that to happen.
I'm now wondering if it IS the graphics card or something else? The first issue seems GPU related but the computer randomly switching off? Maybe thats causing my graphics issues.
System Spec:
Intel Core i5 2500K(tried stock and overclocks)
XFX Geforece 5870 1GB card
8GB RAM
64GB OCZ Vertex3 SSD
DVDRW/1TB HDD
Asus Xonar D2X soundcard
700W PSU
Everythings been running fine up until yesterday :(
Make and model of the PSU?
What motherboard is it?
The motherboard model is Asus P8Z68-V
Not sure on the make and model of the PSU. I just know its a £90 modular PSU from ####### purchased a couple of years ago
Also check your event log. This may help diagnose the problem. Seems a lot of people have been getting this problem just lately.
Well the PSU is a poor, the golden rule around here is never skimp on the PSU quality, but it could also be motherboard related.
P.S, look two posts up;)
Also another thing to try is download MEMTEST and run that.
But how comes the PSU has been coping fine up until recently? :S
I hope its neither that nor motherboard, esp as the motherboard is less than 6 months old from OCuK.
And edited :)
I added a little edit above, but here it is again,
Download MEMtest, which will check your RAM.
Put the CPU back to stock by loading the defaults in the BIOS and try it again.
(if windows fails to boot, set the SATA controller to AHCI or IDE, as this can stop windows booting up when altered which loading the defaults may do)
The CPU is in stock and i've already reset the BIOS. Though thinking about it, that could be whats caused the random shut down as i didn't re-enable hot plugging and didn't check its in AHCI... both of which cause issues with the Vertex3
Also, may I ask, but whats wrong with that PSU I have? I don't understand what makes it a poor PSU and Jeantech have been going for years :S
You could try a BIOS update, if the overclock profile is saved in the BIOS then it will be wiped, if you did the overclock yourself then no worries.
Well,
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story3&reid=123
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=154
http://www.tomshardware.com/reviews/low-cost-psu-pc-power-supply,2862.html
Generally a cheap PSU cant supply the power it claims to do ( a bit like a stereo RMS vs PMPO watts)
Thanks for all your advice guys :)
When i finished work i went to OCuK and got the Gigabyte OC 7950 card at £380 odd.
Runs great :D
