Hi all. This is my first post so please be gentle! I used to think I was fairly computer savvy (built a couple, know enough to do basic BIOS stuff), until I started to look at raid. After 5yrs and 3 unfortunate hard drive failures I have decided to upgrade and at the same time install a raid 1 array. I have an asus p8p67 Deluxe, OCZ vertex 3 120GB SSD to mount the OS and the most used programs and all My Documents info, mujsic video and pics will be on a pair of Samsung 2TB F4's. Obviously these are the two I will Raid. Problem is I've read elswhere about installing the OS (windows 7 home premium 64bit) under AHCI as its newer than Raid, but mobo manual is saying use raid in bios setting. Also I believe windows 7 has software raid, but I can also use hardware raid and then there is an Intel Bios Raid or something? I know what Raid is, there just seems to be such a number of ways of doing it, I'm getting lost! Apologies if there is already a thread for this, I did search but missed it if it was out there. I would appreciate any advice people can give. Finally, I don't think this is possible - I am consolidating a bunch of smaller drives to a 2TB. Can I do this and then raid the disks, or will they have to be formatted to set up the array? Thanks for reading!
