- 14 Jul 2013
- UK
Hi all! I have was running a 3570k @ 4.2Ghz, 1.195vcore and high LLC. This gave me 1.2vcore under full load. I was running like this for a good 12 months if I remember, no issues at all and a max load temp of about 80-85*c.
I have recently bought a second hand 3770k. I thought I would try the same sort of settings. So I tried 1.195vcore and high LLC. This gave me 1.2vcore under full load the same as before. Started at 42x multiplier and got all the way up to 45x before I see a WHEA error. So I backed it down to 44x and now testing more.
The questions I have is temps! This 3770k seems slightly hotter than my old 3570k, I am using HWMonitor to monitor things.
The reason why I decided to back of the multiplier and not up the voltage is due to the loads temps I am getting.
Idle Temps
Core#0 - 36*c
Core#1 - 37*c
Core#2 - 39*c
Core#3 - 30*c
Why is Core#3 so low?
Full Load Temps
Core#0 - 78*c
Core#1 - 89*c
Core#2 - 88*c
Core#3 - 75*c
Now it seems under load Cores#1 and #2 are on average 10*c higher than #0 and #3. How comes? Anything to worry about?
It averages out to about 90-91*c full load after about an hour of Prime95 small FFT's.
Of course I cleaned both CPU and my Cooler Master 212x with TIM Clean and applied some new Thermal Grizzly. HS not seated correctly?
Any help and advice very much appreciated! Thank you!
Edit: Just an update. I have got the voltage down to 1.164 under load, as of now everything is fine. Temps have dropped to a max of 85*c average. A worthy note is though, all 4 cores are now with in 2-3 degrees of each other?
Idle Temps
Core#0 - 36*c
Core#1 - 37*c
Core#2 - 39*c
Core#3 - 30*c
Full Load Temps
Core#0 - 78*c
Core#1 - 89*c
Core#2 - 88*c
Core#3 - 75*c
