Now power after new CPU and BIOS
11 Jan 2025
Uk
Hi all got a head scratcher here
So I have a B650e-e motherboard, today I have just tried to install my new 9800x3d, it threw a 0d error code so I swapped back to my old CPU and downloaded the new BIOS to a USB, made sure it was named correctly and the USB was Fat format. Put in new CPU back in and ran the BIOS flash.
Then went to hit the power button and nothing, no power at all, the only light I have is the RGB on the MB
Been through all the cables so no issues
Any ideas I'm stumped
Done the whole clear CMOS remove battery and all that. Ethernet still blinks green so some power is there.
Hi and welcome.
If you put your old cpu back do you get the same symptoms?
Things to try
Check the CPU socket on the motherboard for bent pins.
Try clearing the CMOS on the motherboard
Try booting with one stick of memory
Flash the BIOS with the old CPU installed.
Hi and welcome.
Things to try
Hi, just done a reflash with the old CPU and same symptoms no power at all
Hi and welcome.
Things to try
I have just tried that and no luck. Could it be a dead MB?
Yes but it could also be the PSU .
Check the CPU socket again Take a picture of the CPU socket and post it so we can check it also, there been a few lately where one pin is bent they didn't notice and posted a pic and I found it.
Yup, those are some damaged pins. You can try to fix them, I guess you have nothing to lose. Looks like at least 4, maybe even 6 if that bottom section covers 3 rows.
Do not put your CPUs back in while they are still bent, you risk bricking those too.
Would those pins be causing the 0 power issue?
Looks like a new MB for me then, had a go at trying to straighten them but not looking much better
Sure would.
You could attempt to fix it but it looks difficult ,there's a guy on here called @Vince He does this sort of thing. Even if you get aother motherboard it mite be worth it .
What's your budget for a board ?
Sure would.
I have already written it off, had a quick go at straightening them but it's beyond my tools and ability.
Have ordered another ROG B650E-E should be here Saturday
Royally annoyed myself as I was gentle as hell putting that new chip in but apparently now enough! Oh well expensive lesson
Thanks all for the trouble shooting!
Your welcome.
Update the bios and put the CPU in before putting it in the case which is a lot easier, you can test it on the motherboard box not the bag before hand if you prefer.
Let us know how you get on.
