I'd like to get a air cpu cooler with Gigabyte b550i aorus. I see the most recommended cooler is Scythe fuma 2, but because of the aorus' unusual cpu socket placement the fuma 2 blocks a 25mm from being installed on the nr200p top.
I'm considering a mugen 5 rev.b but I'm not sure if this would also block a 25mm fan from being used as a top exhaust fan?
As an alternative would installing the fuma 2 but use the included 15mm fan as a top exhaust fan and install a second 25mm fan on the fuma 2 work?
