NTLDR is missing, is there any way to get my data off?
14 Jul 2005
Surrey
Hi all,
Was just browsing the net today when my pc froze and rebooted saying that the NTLDR was missing. It's missing on my 200GB seagate storage drive so i can still boot into windows with my raptor and the seagate unplugged.
Is there any way of getting my data back, the only thing i really want to retrieve is my music collection as everything else i can replace easily but my music will take hours to rip it back onto the pc :(
Windows doesn't boot with the seagate plugged in and also doesn't detect it if i plug it in after it's started booting (is that a risky thing to do :p)
Any help will be great.
BTW This morning i'd been having problems with that drive so i assume that it's dying
you might be able to use something like BartPE to get into a Semi Windows Envorinment, then copy all your needed data into a USB device (or move across the network).
Phnom_Penh said:
Yep, it won't be detected by the motherboard after booting if you use IDE, but it should work ok with usb.
Sounds like a good idea but i'd probably leave that as my last option as i don't want to have to spend extra.
Sounds like it could work, i'm reading up about it right now ;)
emailiscrap said:
Can't you slave it in another computer?
The only other pc that i have with SATA is a dirty Dell one which i could never get my hdd to work on when i tried it before.
EDIT: It's not just a windows problem because the mobo detects that the NTLDR is missing, even with the windows drive unplugged.
Hmm... If it's spinning up, and is detected in the bios, I can't think why it wouldn't work as a secondary drive in another pc. Very odd.
Depending on how much of a hurry you're in, the usb->ide cables off ebay work very well and are only about a tenner.
I'm using SATA ;) Anyway, i've found some SATA to USB converter cables which might be worth a shot if this BartPE thing doesn't work.
Live Linux distros (Knoppix, for example). :)
You can leave both hard drives in, since it only has problems booting into Windows.
Boot off the CD, copy all the files onto a USB/other media. Sorted.
bledd. said:
try using File Scavenger 3
I'll give it a go but if it does find my data then i'll have to buy it to recover my files as the free trial only allows the recovery of files up to 64kb :(
I thought that Linux would be a solution but seeing as i'm a Linux n00b i booted into Damn Small Linux yesterday and didn't have a clue where to find the drives. Do i need extra drivers for sata with Linux?
Thanks for all your help so far guys :)
I'm a Linux noob as well, however, IIRC, your hard drive with the data on will be /mnt/hda2, or /dev/hda2.
I'll update this in a minute if this is wrong, just going to check this out for myself. :)
Edit: changed from /mount/hda2 to /mnt/hda2
