Hi All
I am having a nightmare with my PC at the moment. Tried to use the machine this morning and various issues from being unable to access the start menu/search menu, to windows update not working, soundcard not working etc.
I managed to get the start menu/search menu working via powershell, however I still have major issues.
My soundcard is not being recognised, Soundblaster G6. I now learn that .net framework is missing from my system. tried to add it thorugh windows features, this screen however is blank.
I tried a repair of the installation from a USB drive both within windows and from out. From within windows, it downloads everything and then goes to reboot, but says unable to install. When I try to install from outside, Windows states that my machine is not compatible, which is nonsense.
So completely stuck at the moment, Windows update is not working, I cannot install .net framework, the offline installer does nothing and I cannot re-install windows.
Help.
Help.
) [Enable-WindowsOptionalFeature], COMException
